72 Z1 900 wrote:What a great refurbishment Ed! Is she an early 72 Zed or after the first 2200?
Cheers!
Steve
The engine numbver and frame number are 1 either side of the 2200
ZedEd wrote:72 Z1 900 wrote:What a great refurbishment Ed! Is she an early 72 Zed or after the first 2200?
Cheers!
Steve
72 Z1 900 wrote:ZedEd wrote:72 Z1 900 wrote:What a great refurbishment Ed! Is she an early 72 Zed or after the first 2200?
Cheers!
Steve
Early enough for the early paint and early head possibly, does she have the vacuum ports in the head? I see the ports in the intake rubbers ..... Thanks Ed for this info!
Steve
z2.john wrote:I don't normally pick holes in peoples hard graft, but since you say you want perfection.......your ignition switch is wrong (shouldn't have the cover over where the key enters).
If you want more suggestions, you'll need more close up pics.
Nice bike by the way!!
John
ZedEd wrote:72 Z1 900 wrote:ZedEd wrote:72 Z1 900 wrote:What a great refurbishment Ed! Is she an early 72 Zed or after the first 2200?
Cheers!
Steve
Steve
The engine is 2201 as mentioned in Dave Marsdens book so it seems it could be the best of both worlds
tedsonthezed wrote:Lovely bike Ed.
Regarding vacuum gauge fittings. Up to engine number Z1E-01000, vacuum take offs were a press fit into the head held in with a chemical bond product (which were all replaced with screw thread fittings by dealers). Engines Z1E-01000 to Z1E-02173, the threaded fitting was installed during production. From Z1E-02174 onwards the vacuum take off was in the rubber carb holder.
Got some service bulletins regarding this if you are interested.
