Z900A4 Reproduction seat
RGH
#1 PostAuthor: RGH » Fri Jul 31, 2009 11:58 am
I've got 3 A4 seats, 1 badly bent in middle, other 2 badly cracked and cancer has set in around the edges. Any idea's were to buy a repo? Thanks Hench
FER
Auld Heedyun
#2 PostAuthor: FER » Fri Jul 31, 2009 1:29 pm
Z1 Enterprises , check out links .
fer
mick znone
#3 PostAuthor: mick znone » Fri Jul 31, 2009 2:37 pm
gbh
#4 PostAuthor: gbh » Fri Jul 31, 2009 4:31 pm
mick z1a wrote:http://cgi.ebay.com/ebaymotors/New-SEAT-Kawasaki-Z1-900-Kz900-KZ1000-73-78_W0QQcmdZViewItemQQ_trksidZp4634Q2ec0Q2em14Q2el1262QQhashZitem25555f4bbaQQitemZ160346098618QQptZMotorcyclesQ5fPartsQ5fAccessories
I love how they add, "Made in Japan" in these adverts...
I never knew that Taiwan was part of Japan.. :shock:
tlc
International Rep
#5 PostAuthor: tlc » Fri Jul 31, 2009 4:32 pm
And it`s not an A4 seat anyhow :|
Asphalt Cowboy
RGH
#6 PostAuthor: RGH » Sat Aug 01, 2009 12:59 pm
Thanks for the leads fellas, I've checked these sites and probably everyone in the world to no avail.
I'm amazed how many sellers list Z1/Z900A4/Z1000A1/A2 as the same-same, gets your hopes up, then what the f##k.
Good opening for a supplier to do A4/A1/A2 seats also A1/A2 orig. pipes, must be enough demand?
Hench :(
PJ
#7 PostAuthor: PJ » Sat Aug 01, 2009 2:05 pm
RGH wrote:Thanks for the leads fellas, I've checked these sites and probably everyone in the world to no avail.
Hench :(
Hench, not sure, but I thought you could fit the later lock catch onto these seats rather than the plunger catch?
PJ
000zeds
#8 PostAuthor: 000zeds » Sat Aug 01, 2009 3:51 pm
Z - Power do repro seats that will take both type of seat lock !
Zeds-R-Us
gbh
#9 PostAuthor: gbh » Sun Aug 02, 2009 4:55 am
The two most common reproduction seats are from Doremi and PMC. If you buy a seat from someone ask for the Doremi seat, it is a far higher quality item. The PMC seat is really crappy quality.
RGH
#10 PostAuthor: RGH » Sun Aug 02, 2009 2:40 pm
A replica standard seat for the Z900/Z1000A1/A2. Will also fit the 900/1000 LTD models.comes with hinges/rubbers but NOT the U shaped catch. made in Japan to original specifaction. The cover is not quite right, more like the original z1 pattern.Comes as standard as the American/Export type without the strap however Please order the strap if you need one seperatly.
Available Options:
Seat strap kit (+$29.973a)
Click to enlarge
Thanks all, yes most repo seats take plunger and U bolt but
As can be seen above, all these seats have Z1 series pattern, works out bit expensive one of these plus an A4 repo seat cover, maybe only option.
Thanks again from sunny Aust. Hench.
