I'm guessing quiet a few people on here have them fitted so any advice appreciated, should I send it back or would it be ok to use
New pingel tap
New pingel tap
Got my new pingel fuel tap in the post today, opened the pack and discovered it only has one outlet instead of two, as the 26mm carbs on the A4 are duel feed, I know it's a high flow tap but I presume it should still have two outlets for proper flow instead of me having to put a splitter in the line
- steve bowdler
think you may need this
http://pingelonline.com/powerflo_3311-D.htm
not this
http://pingelonline.com/powerflo_6311.htm
not this
Steve Cooke
Thanks for replies lads, Steve, I was looking at putting a splitter in the line but space between the feed to carbs 1&2 and the tap is limited and unless I used a very roundabout fuel line set up I would have to ditch the inline filter.
Straightline said it was no problem anyway and that they will change the tap for dual feed.
Steve (Debben1), thanks very much, I would have gotten it from you but I was unaware at the time, I do see that you also do the proper lectron fuel hose tho so I will give ya a call to order some of that.
Thanks again.
Thanks again.
- Geoff Meager
- ZedHead
