getting there but need some advice on A2 petrol tap...
mikeyboy1966
...almost at the final hurdle of getting the bike on the road - I put an A2 tank (with petrol tap) onto a B3 Ltd. There's a vacuum pipe from the A2 tap - anyone any ideas where it goes? The bike's running sweet as a nut under 4000 revs after I balanced the carbs but doesn't want to rev any higher, Cheers Mikeyboy
vacuum pipe
Mikeyboy,
On my A2 the vacuum tap take off that you mention goes via a smaller platic tube than the fuel feeds and is connetced to a small stub on the left side of carb no 3 above the floatbowl.
If you don't have that same take off-i wonder if connecting it to the vcuum take off on any of the cylinders would be ok?????????
Regards
Reecy
Regards
Reecy
