engine oil
engine oil
being as im about to rebuild mi engine,what oil would anyone recomend,ive been told not to put synthetic oil in it,as it doesent work proply in these old engines.
engine oil
Hillbilly,
Castrol GTX everytime on these motors.
Reecy
Reecy
castrol gtx seems to be the way to go but i always use semi synthetic. fully synthetic is a waste of money on a road bike. Me mate , a while ago ,explained all about oils, he says semi is up to the same standard as old mineral oil, if not better and wont do any harm. I tend to trust what he says as he works for one of the top tt and bss teams, Mr McGuinness's mechanic and he also races a P and M kawasaki (zed engined). I am Thinking about trying gtx though. Just to see if it makes any difference.
as long as its a motorcycle oil and a well known brand it will be ok.
People say they were designed to run on GTX but that was all they had at the time.
I get your point, especially as there was not much choice back in the days, unless you could afford Silkoline and all that stuff, but when I tried semi synthetic it made the clutch slip. I phoned Castrol on the number given on the oil can and they said go back to GTX.
Rod
Rod
- steve bowdler
I've used silkolene super 4 with no problems or clutch slip and also GTX But i'm gonna use Rock oil TRM20/60 in my project supercharged zed as it's designed for roller bearing cranks . Anyone else used this ??.
