OK,
Quickie, Still awaiting delivery of my standard airbox for the Z so spent today fiddling about and tidying up the shiny bits on the Virago prior to delivery to new owner next week.
Moved the Z to park it once i'd packed all away, started the motor and let it run for a short while.
Stopped and pushed it over to storage and then noticed a puddle of fuel, on inspection it appeared to be coming from Carb 2 overflow, (viewed from left of bike), As you'll likely know it's a vacuum feed fuel line so no vacuum, no fuel.
I'm wondering if the needle valve is the likely culprit here, odds are they've never been touched and the short running has sucked enough petrol in to fill and overflow the bowl?
Z650 carb overflow, errrm, overflowing
