ETCHING PRIMER - Rattle cans
#1 PostAuthor: Pigford » Sat Apr 11, 2009 9:40 pm
A few of you have mentioned the use of ETCHING PRIMER.....
This is for alluminium I believe...... so is it available at most common paint stores : eg Halfords :?:
Wots the sequence.....
#1 degreasing
#2 rubbing down
#3 ETCHING PRIMER
#4 colour paint/top coat...
Redbeard
#2 PostAuthor: Redbeard » Sat Apr 11, 2009 10:09 pm
Halfords do this one, as for the whole process I'm not too sure...
http://www.halfords.com/webapp/wcs/stor ... yId_165625
1979 Z1000ST
#3 PostAuthor: Ginger Bear » Sun Apr 12, 2009 12:31 am
Piggy,
You've got it spot on there! I used 'etch' primer on me wheels cos me paint supplier recommended it. I believe it 'sticks' better than normal stuff. Don't know what it's like to remove though? :shock:
MaineKZ
#4 PostAuthor: MaineKZ » Sun Apr 12, 2009 7:47 am
HI Mr P
FROST Auto Supplies is where I shop - all done on line and top notch gear.
The paint contains a chemical etching agent which eats in to the surface of the ali - means the paint bonds better. That's the theory - seems to work OK!
Your sequence is correct. If you're rubbing back between coats, best to do that between top coats - try not to break the coverage of the primer.
#5 PostAuthor: Pigford » Sun Apr 12, 2009 1:33 pm
Cheers chaps :wink:
Graham, I may well give Frost's a try :!:
#6 PostAuthor: chrisu » Sun Apr 12, 2009 2:08 pm
er - did you mean Chris ?
#7 PostAuthor: Pigford » Sun Apr 12, 2009 3:45 pm
Opppppps, Yes CHRIS sorry, cheers Chris :oops:
#8 PostAuthor: Rich » Sun Apr 12, 2009 4:09 pm
Mark I did it to that sequence and two years later it started to "crack" between the etch primer and colour coats.
After making enquiries - Use the etch primer on alloy only and only in a thin layer, then put normal primer over that and flat back.
Do not use etch on glass fibre (irrespective of what it says on the tin) as the acid makes the gel coat swell which causes it to shrink and craze alarmingly (and stay relatively soft) most automotive paint mixers sell aerosol etch primer, just ring round.
Use a mask.
#9 PostAuthor: Ginger Bear » Sun Apr 12, 2009 5:14 pm
Bl**dy hell Rich,
I wish I'd read this yesterday, Before I did these :|
I'm gonna be stressing for the next two years now, wondering if they are gonna crack up. :fou
compo z1r
etch primer
#10 PostAuthor: compo z1r » Mon Apr 13, 2009 8:52 am
piggy ive etched the engine on my z1r before the final paint in black after speaking to a painter who said it will stop paint flaking to the edge of the fins and make the paint harder over the years to come.
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886
