wow, sounds like a quite a few options... thanks a mill everyone. I'll start slow and easy ' like you say, plenty of time as the carbs are off
cheers
Dave
front caliper bleed nipple sheared.
If the nipple has sheared off flush with the machined face of the caliper you can weld a nut onto the end of it. An 8mm nut will have an internal diameter sufficiently big enough to mig-weld straight through the middle and when its still at red heat and after maybe a half a minute or so put a spanner on and turn it slowly. Not too hot and not too soon but the heat transfer will aid removal.
