Petrol Tap replacement ?????
JonD
#1 PostAuthor: JonD » Sat Oct 04, 2008 6:44 pm
Are there any other petrol taps that will fit a Z900? I need a single outlet to fit 28mm smooth bore carbs with a single center inlet pipe. I have been told that Late model Harleys might fit, somebody must have had the same problem.
regards
Pasc
#2 PostAuthor: Pasc » Sat Oct 04, 2008 6:51 pm
Bang a Pingel on it. Speak to Steve Debben. Web site address in the links section.
JonD
#3 PostAuthor: JonD » Wed Oct 08, 2008 8:19 pm
Thanks I will give it a try
regards Jon
sweptail
#4 PostAuthor: sweptail » Wed Oct 08, 2008 9:30 pm
I recently fitted a new Harley tap single outlet to my 900 with standard carbs. It looks quite good; but I havent done many miles on it. The flow seems quite good. Not sure about bigger carbs tho.Worth a shot at $25 .
Mine leaked in the OFF position on day one: i`ve since turned the seal and all appears to be well. :)
Tommy
