J SERIES ENGINE SPROCKET BOLT - LEFT OR RIGHT HAND THREAD?
Dark Skies
#1 PostAuthor: Dark Skies » Sat Aug 16, 2008 7:46 pm
I figured out how to lock up the sprocket - now I'm scared of leaning on my long bar in the wrong direction.
KZ1000-M1 CSR
Garn 1
#2 PostAuthor: Garn 1 » Sat Aug 16, 2008 8:43 pm
Dark Skies, I have never seen a Left hand thread on the front sprocket shaft. They are always right hand lock nuts or have tab washers, to avoid them coming undone under acceleration. However, I know the feeling .. You don't want to try to turn it the wrong way!
Dark Skies
#3 PostAuthor: Dark Skies » Sat Aug 16, 2008 11:37 pm
Cheers, you were right.
Reason I was concerned was when I started heaving on the bar the bolt gave a bit of a squeak and then locked up solid. "Hmmm. Did I just tighten that?" feeling ensued. Coupled with the concern of stripping the thread and subsequent need for splitting the engine to put a good driveshaft in made me put out a shout.
It's off now though - braced myself, ignored the sensation of popping a gonad and heaved on the bar. Jeeze that puppy was on tight!
KZ1000-M1 CSR
Geoff Meager
#4 PostAuthor: Geoff Meager » Mon Aug 18, 2008 9:19 pm
When you put it back ... use a smear of copperslip & a new tab washer ..
mikey
#5 PostAuthor: mikey » Tue Aug 19, 2008 5:46 pm
Remember this golden rule Lefty loosey...... righty tighty :D
