starting - choke
davy thomson
#1 PostAuthor: davy thomson » Wed Apr 26, 2006 5:43 am
small problem with my z1a when i start it up it fires ok but won't rev like it should on the choke, there is lots of fuel reek and it does not clear till warm ,is this the norm?
Jon
#2 PostAuthor: Jon » Wed Apr 26, 2006 7:23 am
My Harris is the same mate, but then Im running lumpy cams, bigger carbs, etc. I usually start it without the choke to be honest, or put it on and flick it off again straight after starting and watch the throttle for a minute.
#3 PostAuthor: Pigford » Thu Apr 27, 2006 7:40 pm
Sounds like its flooding... too much fuel around, so running rich and won't need so much choke. Could just be a sticky float valve, a bit of sh*te in it, or a leaking float!?
