Hi guys, I need your experience to explain something that is not clear to me:
Sometimes I read treads about fuel hose in particular hoses of 6 and 8 mm, when speaking of 6 mm fuel line, 6mm is the inner diameter of the hose or the outern, I suppose the inner but I want to be sure.
I would like to use a fuel filter for my z1r, the original hose is 6 mm (inner diameter) but I've read that for that bike is better an 8mm fuel hose, what do you suggest 8 or 6 mm hose and fuel filter ?
Second question:
Which tecnical information gives the "fuel starving time" and which is the way to misure it ?
Many thanks to all of you for your patience :-)
Fabio (Italy)
fuel line hose
Zioclive,
The larger the fuel pipe diameter = more fuel flow.
If you only have 6mm, and put a filter in line, this may restrict the flow too much.
Depends how much fuel the carbs are taking, but may not be a problem if you don't ride flat-out
As for - "fuel starving time" -
Not sure what you mean
- RALPHARAMA
bunnysZ wrote:dont they start of narrow and get thicker , thus fitting both 6mm or 8mm...?
The diameter of tube you use is pretty much governed by the diameter of the fittings on your carbs and petrol tap. I have in-line filters on mine, but I'm not sure how much benefit they are. They don't seem to have caught many bricks, and have caused issues with pipe kinking so I may replace the pipes with no filters. They didn't have any as standard.
Ralph Ferrand
- big green bus
zioclive
- Geoff Meager
- ZedHead
inner diameter. you will find that the tube wall thickbness can vary hence outer diameter is not particularly meaningful.
which filter are you using? some are direction - have arrow to show fuel flow.
Note that in our engines the fuel is fed via gravity so thatwould be at a much lower pressure that if there was a fuel pump - maybe that is why you are getting starvation?
remove the filter and if starvation goes away, the filter is responsible.
Today I removed the fule tap and if you ride on the on postion - there should be no need f or any filter - as ^^^ said, they were made without a filter.
