Oil leak
justin taylor
Oil leak
#1 PostAuthor: justin taylor » Mon Jun 09, 2008 11:43 am
Ineed to replace the valve cover gasket on my Z1B as it sprung a leak at the TT.Should i put silicon on the gasket as well?
Dark Skies
Re: Oil leak
#2 PostAuthor: Dark Skies » Mon Jun 09, 2008 12:20 pm
justin taylor wrote:Ineed to replace the valve cover gasket on my Z1B as it sprung a leak at the TT.Should i put silicon on the gasket as well?
No. The gasket alone should be used.
KZ1000-M1 CSR
RALPHARAMA
#3 PostAuthor: RALPHARAMA » Mon Jun 09, 2008 1:34 pm
You should grease the gasket thoroughly. How long ago was the current gasket fitted? If you run around the bolts with a torque wrench you might get away without changing the gasket (8ft/lbs). Don't be tempted to go more though, else you'll be having helicoils fitted :D 3 or 4 hundred after my rebuild I sprung a small weep, but this was solved by a quick whip round with the torque wrench :D :D
Ralph Ferrand
justin taylor
oil leak
#4 PostAuthor: justin taylor » Mon Jun 09, 2008 4:55 pm
Ralph,i nipped up the bolts to no avail.We put the bike in the front of the tent at the TT as it was raining,took the valve cover off and found the gasket to be damaged.A touch of silicon slowed the leak down enough to enjoy the TT.Cheers
