Rear brake master cylinder differences
Robw
#1 PostAuthor: Robw » Thu May 15, 2008 3:33 pm
Hi, does anyone know the differences between an Z1000 R1 and R2 rear brake master cylinder as I am trying to replace the piston with one from Z1 Enterprises.
Cheers Rob
Big John
#2 PostAuthor: Big John » Thu May 15, 2008 4:00 pm
Not sure about differences but would imagine the R1 is the same as a J2 and the R2 the same as a J3. I'm sure Jack will be able to confirm if right or wrong.
86 Z1100R x 2, z7/11r, ZRX400, Z1000B2, ,ZRX1100C4 & Z1000J3.
london calling
#3 PostAuthor: london calling » Thu May 15, 2008 4:31 pm
All that I know for saue is that J1/J2 are different to J3.
You'd have to speak to Phil @ Z-POWER to check the differences between the models.
I can't remember what the difference is,whether it's a longer piston stroke,different diameter piston,different end design to the piston.
Maybe you can cross reference from Kawasaki.com.
If I get chance I'll check my parts manuals,OLD SCHOOL :wink: :wink:
Jack
london calling
#4 PostAuthor: london calling » Fri May 16, 2008 5:36 am
Anoraks ON :roll: :roll:
Here are the part numbers for master cylinder pistons:
1000J:43020-1019
1000R1:43020-1019
1000R2:43020-1036
Part numbers for the brake rod assy,that pushes the master cylinder:
1000J:43010-1004
1000R1:43010-1004
1000R2:43010-1007.
The 1000R1 is listed as a 1982 model,the 1000R2 is listed as a 1983 model.
There are different part numbers for the R1 and R2 complete master cylinder and these also vary between South Africa and Australia.
From the pics in the parts manual,the 1000J/R1 brake rod is longer than the R2 brake rod.
Jack
Robw
#5 PostAuthor: Robw » Fri May 16, 2008 7:36 am
Cheers Jack, I have contacted Z1 enterprises to see if they have the R2 one if not I will try and replace the seals on the piston.
Rob
Robw
#6 PostAuthor: Robw » Fri May 16, 2008 10:45 am
Just a public thanks to Big Green Bus, who has sent me a complete master cylinder when I was only expecting a rod.
Cheers Rob
london calling
#7 PostAuthor: london calling » Fri May 16, 2008 7:54 pm
Rob you wouldn't want a rodding from the Big Pink Sausage :roll: :roll:
You can't get the seals seperately,you have to buy a repair kit including the piston.
Jack
Robw
#8 PostAuthor: Robw » Sat May 17, 2008 8:06 am
:shock:
london calling
#9 PostAuthor: london calling » Sat May 17, 2008 10:22 am
Rob,the Legend that is Big Pink Sausage was the inspiration/idea behind The Full Monty film.
He was portrayed in the film version by Hugo Speer :wink:
Jack
Users browsing this forum: Bing [Bot] and 16 guests
