Z1000 Ltd rear M/c
classkawa
Z1000 Ltd rear M/c
#1 PostAuthor: classkawa » Wed Apr 23, 2008 8:20 pm
Anyone know where I might find a rebiuld kit for a Z1000 Ltd, the one with the long brake rod?
Steady Eddie #21
Skunkwurcx
#2 PostAuthor: Skunkwurcx » Wed Apr 23, 2008 9:40 pm
I ended up getting the bits from Kawi, which do not come as a "kit" for my '77 LTD. I had ordered an aftermarket one from the dealer originally, but when it arrived I found it was the wrong one. The manufacturer of it had listed that it would fit the years with the fluid cup on the unit, when in fact it only would fit the years where the fluid cup is seperate and connected via a hose.
Hope this helps.
Andrew
classkawa
#3 PostAuthor: classkawa » Thu Apr 24, 2008 8:23 pm
Andrew,
Is this like yours? Click on the thumbnail for a larger version
David
[img][img]http://img410.imageshack.us/img410/9674/ltdmcsz3.th.jpg[/img][/img]
Steady Eddie #21
Skunkwurcx
#4 PostAuthor: Skunkwurcx » Sat Apr 26, 2008 9:36 pm
Heya David...I sent you a PM about this but I'll reply here too. Yes, that master cylinder is identical to the one on my '77. I'm not 100% certain, but I believe it was used until 1980. They switched to the seperate resevoirs on the '81's.
Steve Cooke
#5 PostAuthor: Steve Cooke » Sun Apr 27, 2008 6:21 am
Z1 Enterprises !
