Problem with Pilot system
Kari
#1 PostAuthor: Kari » Sun Oct 22, 2006 7:06 am
On of my carburetor does not work correctly. When I adjust the air screw the engine does not changing idle speed. Why? I have tried with another pilot jet and airscrew and cleaning this carbs but nothing help. Those other 3 carbs work correctly. Can anyone help me?
I own an early Z1A
#2 PostAuthor: Rich » Sun Oct 22, 2006 4:19 pm
Check the bleed hole into the venturi is clear.
Kari
#3 PostAuthor: Kari » Mon Oct 23, 2006 3:23 am
What bleed hole? I don't understand. Sending pictures so please show me.
#4 PostAuthor: Rich » Mon Oct 23, 2006 6:02 pm
Number 3 pilot outlet, (there may be two - there are on later carbs) sometimes this gets blocked, clean out the hole wth fine copper wire and blow through to make sure.
Kari
#5 PostAuthor: Kari » Mon Oct 23, 2006 6:36 pm
Okay. Thanks!
Kari
#6 PostAuthor: Kari » Wed Oct 25, 2006 7:06 pm
Yeah... it's work now! Thanks for the help!
