Starter Clutch - Squeal like a pig
- Surfdeneige
Get it sorted sooner rather than later. My starter gear worked loose & sounded like a knackered crank!!!! The starter ring is attached to the rotor (the rotors attached to the ham bone... etc) which is a soft alloy/zinc affair!? If this stays loose for any time it wears fast and needs replacing. Whip off the starter casing and have a good look. There shouldn't be any movement of the rotor and only a bit of radial motion of the starter mechanism as it engages.
- london calling
