Electrics
stevecastle
Electrics
#1 PostAuthor: stevecastle » Wed Feb 08, 2017 6:16 pm
Evening all,
I fitted a new battery today as part of the putting back together processs :D
The idiot brake light bulb was replaced as it had blown, this now flashes permently when the ignition is switched on, rear light and brake light work fine ?
also
Indicators flash very slowly and not a all with the lights on unless i flick the fasher unit then they flash once.
iI guess i need a new fasher unit ?
Any help please
1978 z1000a2 Luminous Green
#2 PostAuthor: warren3200gt » Wed Feb 08, 2017 6:18 pm
Sounds more like a bad conection or earth to me.
PUM 488 June 17
76 Z900A4
77 Z650B1
77 KZ650B1
82 Z1000J2
89 ZXR750H1
92 Blade RRN
#3 PostAuthor: PAULJAC47 » Wed Feb 08, 2017 6:21 pm
Steve, you say idiot light on dash is flashing? this is a feature and is used to indicate that the brake lamp has blown,it does this via the outage relay which is a small grey plastic init that plug into the loom attached to a bracket on one of the coil studs,bit strange though as you say brake lamp is working?ps what is your battery voltage???Paul J
stevecastle
#4 PostAuthor: stevecastle » Wed Feb 08, 2017 6:28 pm
I only rode the bike for a few miles before stripping but did notice slow inictors with a pause before flashing.
Stop bulb did not work as blown
#5 PostAuthor: PAULJAC47 » Wed Feb 08, 2017 6:31 pm
Is the idiot light on all the time or flashing when you brake?
stevecastle
#6 PostAuthor: stevecastle » Wed Feb 08, 2017 6:41 pm
Flashing continously when ignition switched on
#7 PostAuthor: PAULJAC47 » Wed Feb 08, 2017 6:57 pm
You sound like you have a short or outage relay duff,unplug the relay and see what happens?
stevecastle
#8 PostAuthor: stevecastle » Wed Feb 08, 2017 7:08 pm
ok, thanks Paul
I will investigate further at first light
stevecastle
#9 PostAuthor: stevecastle » Thu Feb 09, 2017 5:31 pm
Unplugged the outage relay and the bulb stopped flashing :D
I guess a new relay required.
David suggested swapping the flasher unit with the hazard flasher unit, I did and indicators worked perfectly. :)
New flasher unit ordered.
Thanks all for your help.
#10 PostAuthor: PAULJAC47 » Thu Feb 09, 2017 5:54 pm
Outage relay are pretty rare,do crop up on ebay usa sometimes...
#11 PostAuthor: warren3200gt » Thu Feb 09, 2017 6:56 pm
PUM 488 June 17
76 Z900A4
77 Z650B1
77 KZ650B1
82 Z1000J2
89 ZXR750H1
92 Blade RRN
stevecastle
#12 PostAuthor: stevecastle » Fri Feb 10, 2017 7:19 pm
Got one from the US £21 inc shipping
:D
