Wheel Interchangability
nicomkii
#1 PostAuthor: nicomkii » Fri Feb 03, 2017 7:33 am
Just a quick question from the brains trust.
I'm looking at putting mag wheels from a Z1R onto the A1. Is the rear sprocket carrier and cush drive interchangeable from the spoked wheels across to the mags, along with the brake discs ?
I have got hold of a set of wheels minus sprockets, discs arent a big issue as I have a few floating around.
Nico
000zeds
#2 PostAuthor: 000zeds » Fri Feb 03, 2017 7:57 am
I did this myself and you will need the sprocket carrier + cush drive from the mag wheels :!:
Zeds-R-Us
Kev1R
#3 PostAuthor: Kev1R » Fri Feb 03, 2017 10:02 am
You will probably be aware that depending which Z1R model - some are 18 inch and some are 19's
