dyna coil mounts on mk2/st
Redbeard
#1 PostAuthor: Redbeard » Sun Jan 29, 2017 9:11 am
Hi, does anyone have a pic or some advice for mounting dyna coils on a mk2/st frame please? I think the frame is different to earlier zeds under the tank. Cheers.
1979 Z1000ST
#2 PostAuthor: chrisu » Sun Jan 29, 2017 9:41 am
had no problems on my Mk2s Adam.
Redbeard
#3 PostAuthor: Redbeard » Sun Jan 29, 2017 11:27 am
cheers chris. is it secondary posts up and forward as with others? any brackets needed?
1979 Z1000ST
#4 PostAuthor: chrisu » Sun Jan 29, 2017 1:41 pm
no other brackets needed - just be careful as always with any risk of shorting out.
Redbeard
#5 PostAuthor: Redbeard » Sun Jan 29, 2017 2:10 pm
Just checking, is this the same as the mk2?
Next to coils;
1979 Z1000ST
#6 PostAuthor: chrisu » Sun Jan 29, 2017 3:00 pm
now thats interesting......
no - very different from a Mk2
Mk2 is same as earlier Zs.
Redbeard
#7 PostAuthor: Redbeard » Sun Jan 29, 2017 7:27 pm
Bollocks. Yet another variation between these two. Would there be any issues if I had the coils on their sides?
1979 Z1000ST
#8 PostAuthor: zed1015 » Sun Jan 29, 2017 10:25 pm
Redbeard wrote:Bollocks. Yet another variation between these two. Would there be any issues if I had the coils on their sides?
No, Put them anywhere you can.
Upside down, back to front. Doesn't matter.
oldzed
#9 PostAuthor: oldzed » Mon Jan 30, 2017 2:29 pm
There should be a triangular bracket that hangs down on each mount like below
http://www.ebay.co.uk/itm/1982-Kawasaki ... Sw4DJYi6OG
member number 0664
Who can catch a Kawasaki?
A police helicopter
Redbeard
#10 PostAuthor: Redbeard » Mon Jan 30, 2017 7:29 pm
Cheers Rob, will do. I eventually (after a lot of searching) found a pic of some mounted on their sides on an ST.
oldzed, the ones that came off it were fitted to home-made, crap brackets which I have re-made. I will mount them once the new dyna leads arrive and keep my eye out for the proper brackets.
1979 Z1000ST
