B2
big green bus
B2
#1 PostAuthor: big green bus » Sat Jan 14, 2017 9:03 am
Can anybody send me the wiring diagram to change the oil light from level to pressure or just how to put the digital light off on B2 clocks. :oops:
#2 PostAuthor: z1bman » Sat Jan 14, 2017 9:35 am
to put the light of short the wire to earth . if you are going to change from a level to pressure you will need to find the fitting from an earlier model like this
http://www.ebay.com/itm/Kawasaki-92005- ... 1886424672
big green bus
#3 PostAuthor: big green bus » Sat Jan 14, 2017 6:09 pm
I have got B2 clocks with a B1 pressure switch so now the light is out, but comes on when if fires up. At worst I will just wire in an oil light in if I cannot sort the B2 display
needaz1100r
#4 PostAuthor: needaz1100r » Mon Jan 16, 2017 9:47 am
Are you saying the light is off with the ignition on and comes on when the engine is started?
If so that is an easy fix with a 12v relay.
If you confirm that's what happens I will draw you a mod to change it.
Mark.
big green bus
#5 PostAuthor: big green bus » Thu Jan 19, 2017 6:13 am
Yes matey that is the crack :lol:
