Oil cooler hose replacement 1984 Elr
Stugill
#1 PostAuthor: Stugill » Tue Jan 03, 2017 11:28 am
Good morning.
Got my engine out yesterday and one of the oil cooler hoses looks a bit cracked.
It did not leak before the strip down so it is not too bad, but I thought that whilst tidying it up I would look into replacements.
They are no longer available via Z power.
I have the original standard oil cooler.
Any ideas where I might be able to get them?
Stu
#2 PostAuthor: ADRIAN H » Tue Jan 03, 2017 12:35 pm
AN-8 Stealth fittings from this seller work.
http://stores.ebay.co.uk/Torques-U-K
Stugill
#3 PostAuthor: Stugill » Tue Jan 03, 2017 1:22 pm
Thanks.
I will take a look.
Stu
Stugill
#4 PostAuthor: Stugill » Tue Jan 03, 2017 1:24 pm
Thanks.
I will take a look.
Stu
doebag
#5 PostAuthor: doebag » Tue Jan 03, 2017 3:08 pm
Pirtek should be able to put new hoses on your original connections
http://www.pirtek.co.uk/
'Dying a'int much of a living, boy'
Outlaw Josey Wales
Member No. 555
#6 PostAuthor: Al » Tue Jan 03, 2017 10:16 pm
The bolted flange is silver soldered to the spigot that carries the hose.
The crimp 'cup' is in turn; silver soldered to the spigot, the hose later inserted and the cup is then 'waisted'.
Removing the hose is an absolute git, as is un-soldering the crimped cup without releasing the spigot from the bolted flange at the same time.
Stugill
#7 PostAuthor: Stugill » Wed Jan 04, 2017 7:15 pm
Thanks for replies.
I took it to my local pirtek and they will do it. He proposes to cut off the collars, (which can't be replaced) weld a collar on and connect the new hoses. He reckons it will be £35 per hose. I will let you know how it works out.
Stu
Stugill
Possibly a picture of the new hoses
#8 PostAuthor: Stugill » Wed Jan 11, 2017 9:30 am
The photo is not great, but the replacement hoses are, they even flex without cracking. £67- happy with that. new rubber seals included.
Stu
Users browsing this forum: Google [Bot] and 14 guests
