Original rectifier/regulator worth keeping ?
mike_p
#1 PostAuthor: mike_p » Mon Jan 02, 2017 10:40 pm
My z1000a2 still has the original separate regulator/rectifier setup on it. The rectifier certainly looks its age and as I'm in the process of completely rebuilding the bike I'm wondering if it's worth upgrading/replacing them both with a single setup as the bike will be getting used as a daily ? Any recommendations.....or is the original kit very reliable ?
KeithZ1R
#2 PostAuthor: KeithZ1R » Mon Jan 02, 2017 11:54 pm
realistically one of them will fail eventually purely on age, however having said that if it is working now and giving the correct output at around 13.5` 14 volts under full load at 4000 rpm there is no reason to swap it for the sake of it, just buy a replacement integrated unit and put in a box ready :up just my opinion you understand ...other opinions will be along presently :D
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
#3 PostAuthor: z1bman » Tue Jan 03, 2017 12:01 am
chuck it in the bin unless its for show
nzphil
#4 PostAuthor: nzphil » Tue Jan 03, 2017 12:24 am
Bin it, I kept mine on for far too long and eventually it crapped out & took my Dyna S with it.
73 Z1, HondaCRF 450
Most of my money has been spent on Z's, beer & women,
The rest has been squandered.
#5 PostAuthor: ADRIAN H » Tue Jan 03, 2017 9:18 am
Bin it, my original took out the alternator wiring.
mike_p
#6 PostAuthor: mike_p » Tue Jan 03, 2017 9:35 am
Cheers guys, it looks like I'll be converting it to a modern setup then. I'll not bin em though I'll box them up all with the other standard bits I've removed just to keep them with the bike
Steve Cooke
#7 PostAuthor: Steve Cooke » Tue Jan 03, 2017 6:11 pm
Get shut they're crap! they weren't too reliable when new so even more dodgy now, there's a good chance they will cook your wiring or maybe worse battery acid over your pipes etc.
#8 PostAuthor: PAULJAC47 » Tue Jan 03, 2017 7:24 pm
Just got a couple of brand new Cbr600 jobbies tenner each,will adapt them with the old plugs for both my projects,seen too many exhausts ruined with batteries boiling...
Kev1R
#9 PostAuthor: Kev1R » Tue Jan 03, 2017 11:11 pm
Yes mine did exactly what Pauljac says - around 1990 when the unit was, I suppose around 12 years old.
After a run out, the battery had boiled dry and was too hot to handle.
With adverse affect on Chrome exhaust!
Acquired a modern replacement in since then & everything ok - I think I got the replacement from electrexworld
From that experience I decided I did not want an original item back - even if I could find one!
010
#10 PostAuthor: z1bman » Tue Jan 03, 2017 11:26 pm
don't get fooled here yes the original regulator was not up to the job but even the modern units can fail especially the H**** ones if you are replacing the regulator i would strongly advise to replace the battery to a gel type as these wont spill acid all over your £1000 + exhausts
flateddie
#11 PostAuthor: flateddie » Wed Jan 04, 2017 9:53 am
yep get rid!! mine completely cooked the whole loom on my 1000a1
#12 PostAuthor: PAULJAC47 » Wed Jan 04, 2017 10:12 am
Yes agree with Z1b man always use Agm batts now,but have not had any probs with any Hodna combined units,would hazard a guess most of the units on sale now are made in Prc now ,,,,
KeithZ1R
#13 PostAuthor: KeithZ1R » Wed Jan 04, 2017 10:46 am
Told you :lol:
Keith
:bop :gom
mistaken.
