I'm working blind at trying to put together all the elements of the fI system on the B1 (thanks in no small measure to Mattc here on the board for parts!).
I want to get everything hooked up correctly before attempting to start the bike for the first time.
I have been testing the components via the FSM and everything is looking good. Here's the "But"...
Where the harness connects to the Control Unit in the tail piece, the harness has a particular 'set' that seems to indicate the way round it connects to the module. Here are some pics
[img][img]https://c6.staticflickr.com/1/487/31195736573_e87ed0843c_b.jpg[/img]IMG_2669 by shakeydrummer, on Flickr
The module here is sitting the 'right' way up position according to the securing tabs and label.
However, it looks like this way round, the connector is the wrong way up for the module.
[img][img]https://c1.staticflickr.com/1/552/31967738496_e0530dcfb5_b.jpg[/img]IMG_2675 by shakeydrummer, on Flickr
In this position the port on the module looks like this:
[img][img]https://c8.staticflickr.com/1/260/31195740583_99700edbe9_b.jpg[/img]IMG_2671 by shakeydrummer, on Flickr
note particularly the chamfered corners of the white connector block; the central upper locking tab; and the lower central connector pin...
The harness connector however looks like this...
[img][img]https://c6.staticflickr.com/1/260/31888423301_b041042746_b.jpg[/img]IMG_2670 by shakeydrummer, on Flickr
So either the 'set' of the cabling means the module has been connected 'wrongly' for all these years (unlikely) or it is supposed to be like this (also unlikely as the locking tab wouldn't work and the central pin would not connect to anything).
Can anyone shed any light on this? My hunch is to follow the connector/pin pattern against the suggestion of the harness. But..., I wonder...
GPz1100B1 another electrics question
shakeydrummer
- Regular Poster
GPz1100B1 Restoration
Julian_Boolean
shakeydrummer
- Regular Poster
gpz1100 b1
Turn the ECU round its easier
GPZ1100 B2 owner
GPz 305 project
99% Gpz1100 unitrac Nearly there
GPz 305 project
Re: gpz1100 b1
1962royp wrote:Turn the ECU round its easier
the ecu is the rite way up its the plug that's wrong
