Front wheel removal without centre stand.
1978 z1000 with a 4 into 1 V and H pipe. What's the best way to lift bike to allow wheel removal? Thanks Ian.
- warren3200gt
Get yourself one of these. comes in handy in all kinds of situations when you don't have a centre stand.
http://www.ebay.co.uk/itm/500KG-Motorcy ... SwsTxXjGl5
									PUM 488 June 17
76 Z900A4
77 Z650B1
77 KZ650B1
82 Z1000J2
89 ZXR750H1
92 Blade RRN
						76 Z900A4
77 Z650B1
77 KZ650B1
82 Z1000J2
89 ZXR750H1
92 Blade RRN
				Julian_Boolean
With bike on side stand get yourself an axle stand or similar, push right hand side of bars back and towards bike until bike front wheel lifts and pivots on side stand and rear wheel. You should find the weight is trying to keep sidestand down....not push it up. Put an axle stand under right hand side of frame towards front (putting something on top of it to protect paint....piece of old inner tube etc).....job done. Check stable obviously and that axle stand can't slip before removing the wheel ! I've used this method for years on all sorts of bikes with no problem.
						Thanks for the ideas. I know I have dealt with this problem in my distant past, trouble is my memory has faded... I want to get the wheel off to replace the tyre. Can I assume that a bikeshop would supply and fit if I just took bike to them? If so any suggestions as to where to go in the Midlands?  Near nuneaton would be good.
Ian.
						Ian.
I got one of these.
Very happy with it but must be used with rear stand.
https://www.ebay.co.uk/itm/310226107466
Asphalt Cowboy
- SVENLEATHER
tlc wrote:I got one of these.
Chris, I guess your stand is quite old. Tried going down that route but found the modern stand not tall enough for a zed.
SVENLEATHER wrote:tlc wrote:I got one of these.
No Chris.
I merely made up some new plates which extended the length to suit.
Seeing as the J models have the longest forks I wasn't surprised I had to do this.
Asphalt Cowboy
