The current slave cylinder on my Z1R is a of uncertain origin and leaking. i've had a few suggestions as to what it might be but not found a match in real life yet. The existing cover has been modified specifically for this slave cylinder.
so........
I was going to go for an outrigger plate as i also have a 530 offset sprocket which needs an outrigger bearing capability. I can then (hopefully) mount the new Falk slave cylinder i have.
Whats the current plate of choice ?
outrigger sprocket bearing holder plate - vendors of choice?
