Sprocket spacer
harri183
Sprocket spacer
#1 PostAuthor: harri183 » Mon Oct 03, 2016 9:11 pm
Does the spacer that sits between the rear sprocket and hub fit to all types of chain and sprockets or is it just for different sizes. Cheers in advance
000zeds
#2 PostAuthor: 000zeds » Mon Oct 03, 2016 9:27 pm
It is standard on Z1B and part number is 92026-108
Zeds-R-Us
C Martin
#3 PostAuthor: C Martin » Mon Oct 03, 2016 9:37 pm
The spacer was fitted by Kawasaki on the z1b when they fitted the o ring chain as it is slightly wider than the non o ring chain which was fitted to the z1 and z1a
Chris
73 z1, z650c3, zrx1200R A6F, KH400a4
ALWAYS LOOK ON THE BRIGHT SIDE OF LIFE
harri183
#4 PostAuthor: harri183 » Mon Oct 03, 2016 10:35 pm
#5 PostAuthor: ZedHead » Tue Oct 04, 2016 10:37 am
Original spacer is no longer available. I had some stainless ones laser cut.
harri183
#6 PostAuthor: harri183 » Tue Oct 04, 2016 10:39 am
I was looking last night and saw them on your site. :) Cheers
