Push Pull throttle?
LeeJackson
Push Pull throttle?
#1 PostAuthor: LeeJackson » Sun Sep 25, 2016 9:03 am
Hi guys, I need to order up a push pull throttle for my flat slides. I see so far only two options, motion pro and APE. Are there any others? These look pretty similar but is one better than the other? Am I missing any better options? Had some bad experience with aftermarket throttles before so thought best to check :)
Lee
martinz1000r
#2 PostAuthor: martinz1000r » Sun Sep 25, 2016 10:51 am
I use motion pro. I think you'll find the APE version is Motion Pro too. No issues at all other than the allen screws at handlebar end are steel and rust in seconds. Easy fix though. I also have a Yamaha twin cable throttle but the motion pro has longer cables so easier to get decent routing.
If you are using CR carbs connect the cables before you fix the carbs in to the rubbers otherwise your fingers just wont bend in enough angles.
#3 PostAuthor: Al » Sun Sep 25, 2016 1:41 pm
As above. I have a motion pro from Ray on 36mm RS flatslides like you now have. No issues, straight fit no drama. Spare cables are also available. Had a DR 400 Suzuki one before and was quoted £40 just for new cables!
LeeJackson
#4 PostAuthor: LeeJackson » Sun Sep 25, 2016 2:17 pm
Thanks guys. I'll get one of them ordered from Debben
tlc
International Rep
#5 PostAuthor: tlc » Sun Sep 25, 2016 7:25 pm
I use the same and just bought new cables for it.
No dramas and looks dead cool.
Asphalt Cowboy
#6 PostAuthor: Pigford » Sun Sep 25, 2016 9:06 pm
I'm using a Yam R1 throttle assembly on me harris - works good.
HowieD
#7 PostAuthor: HowieD » Mon Sep 26, 2016 8:29 pm
Horace is fitted with a universal Push / Pull kit from Venhill
CD185, Maggot, Z1-R, Horace
