LHS Handlebar Switch Z900-A4
Garn 1
#1 PostAuthor: Garn 1 » Sat Sep 24, 2016 10:27 am
Anyone struck this..
My latest project is complete o'haul of a Z900-A4 !976 also known as a KZ900 in USA.
My problem is I acquired a harness for above mentioned model some years ago.
I also acquired a Left Hand side switch unit.
My harness has a 4 pin connector and my LHS switch has a 6 pin connector.
I really don't need this six pin connector LHS switch I'll have to convert it to a 4 pin!
I think the trouble arose in providing passing lights in the later models (Z1000-A1).
I'll probably sort it out in the long term.... Anyone got an easy fix?
RegardZ
#2 PostAuthor: z1bman » Sat Sep 24, 2016 12:22 pm
you need a switched live = brown wire & red with black trace which goes to the high beam side of the headlight bulb if you open the harness where the 4 pin block connector enters the main harness you will be able to tap of these wires. remove the original 4 pin connector & replace it with a 6 pin connecting the other two wires
z2.john
#3 PostAuthor: z2.john » Sat Sep 24, 2016 1:24 pm
Hi Garn,
Try these if you want the block
http://vintageconnections.com/
Garn 1
#4 PostAuthor: Garn 1 » Sun Sep 25, 2016 12:14 am
Thanks guys problem solved.
