excessive oil and burning oil
bunnysZ
Granny Magnet
#1 PostAuthor: bunnysZ » Fri Sep 16, 2016 9:46 am
on top of the crankcase is the body breather ,(chrome dome) which has a pipe that feeds into the air box, i have K&N filters so i have added a pipe which feeds up under my seat into a small filter.
I noticed a lot of smoke and burning oil smell from there the other day, and around the chrome dome it is damp with oil. i removed the body breather today and there is a pool of oil sitting in the recess .
is this a sign of a problem or start of a problem. bike is not burning loads that I have to keep topping it up,
#2 PostAuthor: ADRIAN H » Fri Sep 16, 2016 10:01 am
you need an oil catch tank -
http://www.debben.co.uk/obct.html
#3 PostAuthor: z1bman » Fri Sep 16, 2016 10:29 am
smoke or vapor? smoke means rings are suspect vapor is normal. yes you will find oil under the breather cover
Charlie
#4 PostAuthor: Charlie » Fri Sep 16, 2016 12:29 pm
I route mine to underneath the motor (away from the back tyre). No smells, no smoke, no oil drips :wink:
#5 PostAuthor: chrisu » Fri Sep 16, 2016 8:41 pm
need to do a leakdown test paul
#6 PostAuthor: ZedHead » Sat Sep 17, 2016 9:52 am
chrisu wrote:need to do a leakdown test paul
+1 Excessive oil and burning smell from breather sounds dodgy to me
Mark Tiller
#7 PostAuthor: Mark Tiller » Sat Sep 17, 2016 1:21 pm
Oil in the dome don't worry, Zeds with higher mileage prefer not to be filled up to the high mark especially when ridden with vigour
