rear shocks
geraldknight
rear shocks
#1 PostAuthor: geraldknight » Sat Aug 27, 2016 6:58 am
Hi, Is there anyone who refurbishes rear shocks, mine are a little rusty & need dismantling & rechromimg. No oil leaks. I prefer these to the pattern ones. Many thanks Gerald Knight
Gus
#2 PostAuthor: Gus » Sat Aug 27, 2016 11:20 am
"Set the GRINDER on it"
#3 PostAuthor: ZedHead » Sat Aug 27, 2016 12:28 pm
I am sure someone on here fabricated a spring compressor using plates and long bolts? Once dismantled you just need a good plater.
wilsonsjw11
#4 PostAuthor: wilsonsjw11 » Sat Aug 27, 2016 1:09 pm
What bike are we talking about.
Regards
Steve
geraldknight
Z1B
#5 PostAuthor: geraldknight » Sat Aug 27, 2016 2:43 pm
Sorry Steve i have a Z1B900. Thanks for the post
harri183
#6 PostAuthor: harri183 » Sat Aug 27, 2016 2:58 pm
Main has made a tool for it but yes it's re chrome Spring spray the top. There's a locating pin in the top. If you search on projects sure it's on his z1 build. I have a set of z1b shocks to do as well.
harri183
#7 PostAuthor: harri183 » Sat Aug 27, 2016 3:04 pm
wilsonsjw11
#8 PostAuthor: wilsonsjw11 » Sat Aug 27, 2016 4:43 pm
geraldknight,
I have a home made spring compressor and pin punch that you will require to strip and rebuild the rear shox.
Be selective on who you get to rechrome the damper etc as it needs to be a thin coating.
Unless you are looking for a total original rebuild you can buy a pattern pair,strip the damper off then rebuild with original parts.
Regards
Steve
geraldknight
rear shocks
#9 PostAuthor: geraldknight » Sat Aug 27, 2016 9:50 pm
Thanks very much for the information to everyone for the posts, much appreciated.
Users browsing this forum: Google [Bot] and 20 guests
