Cams
King of Kings
Cams
#1 PostAuthor: King of Kings » Fri Aug 19, 2016 11:02 pm
Can the camshafts stay in situ when removing the cylinder head??
#2 PostAuthor: chrisu » Sat Aug 20, 2016 5:54 am
Nope
You need to remove cams to get the cam chain off
#3 PostAuthor: Pigford » Sat Aug 20, 2016 7:48 am
Or.............. you could cut the chain - and refit with a replacement "rivet" type chain :wink:
Re: Cams
#4 PostAuthor: zed1015 » Sat Aug 20, 2016 11:36 am
King of Kings wrote:Can the camshafts stay in situ when removing the cylinder head??
No and you also must not refit both cams to the head once off as you risk bending valves.
