bone jarring forks
bone jarring forks
when out today when riding over a dropped kerb,the front forks gave a bone jarring knock, felt as if the front tyre was very low and hit the rim (first thing I checked), could not enough oil or too much cause this?
Many years ago I tried raising the fork oil quantity by 45ml.
I then bought a tool to take it back out again.
From memory as standard I had about 3 or 3.5 inches of movement but with the raised level only 1.5 inches.
You really need to stomp on the brakes to find out exactly how much movement you've got.
Asphalt Cowboy
