Fuse box upgrade
Fuse box upgrade
Thinking about upgrading the fuse box on my a4, recently had a couple of fuses fall to bits so want to change to a blade type. Where can I get a replica block connector from?
or here:
http://www.bikerstoolbox.co.uk/acatalog/info%5fNumber%5fof%5fFuses.html
http://www.bikerstoolbox.co.uk/acatalog/Wiring_Supplies.html
if you open an account, there's Z1 OC discount as well
H
H
CD185, Maggot, Z1-R, Horace
this one is much neater job with the wiring going to the back of the fuse box
http://www.ebay.co.uk/itm/4-Way-12-Volt ... 2c800f1441
Or you could go this way:
http://www.z1ownersclub.co.uk/forum/viewtopic.php?t=25597&postdays=0&postorder=asc&start=375
available here:
http://www.vehicle-wiring-products.eu/section.php/248/1/modular-fuse-relay-housing-system
available here:
