Ignition key
Ignition key
I have an ignition switch without a key, for a z1b i think. there are two sets of markings on it Z 70 and 7  68.  On ebay some is selling original keys is 768 the code?
						- warren3200gt
The number on the barrel is the key number and should be in the range 751-755 on a Z1B. I supply them all the time no problem. The only problems arise with the new pattern switches which are stamped with a Kawasaki correct number but the keys do not in fact match the numbers.
I charge £10 for keys pm me if you want one. If you cant find the number you can send me the switch and I can work out which key number it is.
