Z1000 rotor?
King of Kings
Z1000 rotor?
#1 PostAuthor: King of Kings » Sun Apr 17, 2016 4:56 pm
Hi all, is it possible for a fooked alternator rotor, to sound like something amiss within the front of the camchain tunnel? Have pinpointed a low clanging noise from the front top of the head? :(
#2 PostAuthor: z1bman » Sun Apr 17, 2016 5:19 pm
could be the exhaust valve guides
KeithZ1R
#3 PostAuthor: KeithZ1R » Sun Apr 17, 2016 7:07 pm
when the rotor starts to come loose on the carrier it sounds like a big end knocking :shock:
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
#4 PostAuthor: Pigford » Sun Apr 17, 2016 7:44 pm
Yes is the answer :!:
#5 PostAuthor: paul doran » Sun Apr 17, 2016 8:04 pm
Pigford wrote:Yes is the answer :!:
incorrect
if the rotor is fucked it will sound exactly like Keith described and it will not be in anyway tinny
You cannot mistake it believe Me
King of Kings
#6 PostAuthor: King of Kings » Sun Apr 17, 2016 9:48 pm
Thought so, just clutching at straws! It's in the chain tunnel, tensioner wheel/blade?
#7 PostAuthor: zed1015 » Sun Apr 17, 2016 10:30 pm
Probably the little front slipper guide has broke and the noise is the camchain slapping about.
#8 PostAuthor: Pigford » Mon Apr 18, 2016 6:40 am
When my rotor was working loose... it started as a light rattle then it went thru a tinny noise... then started knocking (all within the space of < 100 miles). That was on my old Z1000 :!:
King of Kings
#9 PostAuthor: King of Kings » Mon Apr 18, 2016 11:40 am
Aye Piggy, remember it happening on this bike 35yrs ago! Ah well, new rotor and starter clutch unit it is then! :)
Garn 1
#10 PostAuthor: Garn 1 » Wed Apr 20, 2016 11:50 am
No! It will just be those 3 hex headed bolts at the back of the rotor that have come loose... Re-tighten.. You could get lucky!
RegardZ
King of Kings
#11 PostAuthor: King of Kings » Wed Apr 20, 2016 6:15 pm
Fraid not, rotor is virtually in two pieces! Smacked all the stator windings in the casing, bent the mounting bolt too! Will the A2/Z1R rotor fit the A1 crank? :(
#12 PostAuthor: z1bman » Wed Apr 20, 2016 7:00 pm
King of Kings wrote:Fraid not, rotor is virtually in two pieces! Smacked all the stator windings in the casing, bent the mounting bolt too! Will the A2/Z1R rotor fit the A1 crank? :(
same part no according to the parts book
#13 PostAuthor: Pigford » Wed Apr 20, 2016 7:01 pm
Garn 1 wrote:No! It will just be those 3 hex headed bolts at the back of the rotor that have come loose... Re-tighten.. You could get lucky!
RegardZ
+ 1 Thats what had happened on mine.
Sounds like you were too late with yours - bummer :cry:
King of Kings
#14 PostAuthor: King of Kings » Thu Apr 21, 2016 5:53 pm
Gonna have to stop revvin the old girl thru to 9000! Never mind, all sorted now! :)
Users browsing this forum: Google [Bot] and 14 guests
