Header temperature
Header temperature
If you put a heat gun on  the top of the headers ,nearest the head  .what temperature would you expect to see in Celsius
						- paul doran
- paul doran
Doesn't sound like a problem if it ran ok and all the pipes are the roughly the same colour if chromed or stainless.
Air cooled motor, stood at the lights = increased heat.
Anything hotter than a fart will produce heat haze.
Engine and pipes will be more than a few hundred degrees at least.
Worrying for nothing.
- steve bowdler
