Carbs for A4
Rodders5019
Cheers guys thank you for your comments . I am sorry if this has turned in to a bit of a debate, I will be asking Dave for prices as well as shopping around for other quotes. I am having the work done by Grumpy 1260 so will ask there advice on what carbs are best suited to the bike as well. Thank you for your advice GB and will take them into account when choosing .I am not looking to up the power or anything just get it running sweet.
Rodders PUM
( REX1100 Z900 A4 )
( REX1100 Z900 A4 )
Guys,
Personal Opinion
this board should be supplier neutral. If someone (for whatever reason) is able to supply parts cheaper than anyone else then good luck to them. We need competition.
I've bought from Dave, Zpower and Jeff and others as needed. Sometimes I price check, sometimes I don't.
Dave - you need to be less cryptic in your use of emoticons as your point in this post was very easy to misunderstand. I took it as a criticism of z1enterprises.
Personal Opinion
chrisu wrote:Dave - you need to be less cryptic in your use of emoticons as your point in this post was very easy to misunderstand. I took it as a criticism of z1enterprises.
Ah, I now see another side of how it could have been interpreted - didn't think of that angle.
Pigford wrote:chrisu wrote:Dave - you need to be less cryptic in your use of emoticons as your point in this post was very easy to misunderstand. I took it as a criticism of z1enterprises.
Neither did i
That is all i have to say, i will supply my quote and let Rodders make his own mind
Rodders5019
