Rear wheel off set 900 A4?
Keefleaf
#1 PostAuthor: Keefleaf » Mon Mar 14, 2016 1:38 pm
I did a 'site search' but only found similar question re: Z1000 rear wheel.
Seeing as Z1000 has disc brake rear and the Z1 900s have drum brake guess it could be different. Also noticed Wayno asked the same question but got no reply. I've sent hubs and Borrani type Ali rims to Devon wheel Co,so need to let him know. Worst case I'll send him a standard rear wheel to measure.
Anyone know?
Thanks,Keith.
#2 PostAuthor: chrisu » Mon Mar 14, 2016 6:47 pm
pretty sure the answer is none.
Keefleaf
#3 PostAuthor: Keefleaf » Mon Mar 14, 2016 9:07 pm
Cheers Chris.
Think I should look on you tube,measure wheel off set,then check my other Wheel.
Steve Cooke
#4 PostAuthor: Steve Cooke » Tue Mar 15, 2016 6:21 pm
None
#5 PostAuthor: z1bman » Tue Mar 15, 2016 6:49 pm
it doesn't mention anything in the Kawasaki manual about offset so i would presume there isnt any?
Keefleaf
#6 PostAuthor: Keefleaf » Thu Mar 17, 2016 12:57 pm
"Thank you" :wink:
Garn 1
#7 PostAuthor: Garn 1 » Tue Mar 22, 2016 5:04 am
A4 rear wheel is the same rim and hub as Z1, Z1A and Z1B..... No offset!
