gpz1100 oil leak
carlferguson
gpz1100 oil leak
#1 PostAuthor: carlferguson » Sun Mar 13, 2016 1:00 pm
Hi there, I'd noticed a small oil leak on my gpz1100 b2 so decided to investigate. I removed the sprocket cover, wiped every thing down and waited for a while. Went back and it looks like its leaking from the gear shift shaft, is this common and is there an easy fix, or is it a complete dismantle job?
any advice appreciated.
cheers carl
#2 PostAuthor: z1bman » Sun Mar 13, 2016 3:39 pm
new oil seal just prize it out & tap a new seal in
carlferguson
#3 PostAuthor: carlferguson » Mon Mar 14, 2016 7:52 pm
cheers z1bman, any tips on how to get the old seal out? I've been trying for a couple of hours to no avail. I seem to have pushed it in more than getting out. I'm not the best with the spanners but I don't mind trying.
#4 PostAuthor: z1bman » Mon Mar 14, 2016 9:20 pm
use one of these type of corkscrews
https://en.wikipedia.org/wiki/Corkscrew
Mr Bump
#5 PostAuthor: Mr Bump » Tue Mar 15, 2016 8:40 am
Its worth checking that the hole in the sprocket cover isn't too badly worn...
carlferguson
#6 PostAuthor: carlferguson » Tue Mar 15, 2016 5:19 pm
after spending 2 hours trying with the wrong tools to extract the oil seal, I went today to buy a hooked type tool {screw driver with a hook on} it took about 3 minutes to get it out. Put it all back together and it all seams ok. Amazing what you can do with the right gear.
