GPz1100 oil cooler onto a "J" ?
Maybe a daft question - by I assume a GPz1100 B1/2 oil cooler system will fit straight onto a Z1000J
martinz1000r
i think so. I think the J just has the pressure switch behind the barrels and the take offs then just bolt on with the switch integral.
If you need the parts I can probably sort out oil cooler, lines and take off plus even the mounting point for the frame although I think the twin horn mounts have been removed. I think i have both ELR and GPz Unitrak in the shed.
As it's you a special (inflated) price could be agreed
martinz1000r wrote:i think so. I think the J just has the pressure switch behind the barrels and the take offs then just bolt on with the switch integral.
Martin, appreciate that - cheers matey.... only need the mounting plate if I go down that route
