Z1000 a2 exhaust
Marmitemartian
Z1000 a2 exhaust
#1 PostAuthor: Marmitemartian » Tue Feb 02, 2016 7:19 pm
I have an exhaust silencer which needs a repair, I'm considering cutting the reverse cone off a z650 exhaust and tig welding it to my damaged exhaust then having it rechromed, any one know if the 650 cone is the same as the 1000? Or any better ideas, anyone have a lovely nos offside silencer sat doing nothing in the loft :roll: ok so back to the repair job.
[img]https://www.dropbox.com/s/0xckass7rfvwfst/z1000exhaust1.jpeg?dl=0
[/img]https://www.dropbox.com/s/tmsxhu706t8y6lg/z1000%20exhaust.jpeg?dl=0
#2 PostAuthor: warren3200gt » Tue Feb 02, 2016 7:44 pm
Not sure but can take 650 dims if you need them.
PUM 488 June 17
76 Z900A4
77 Z650B1
77 KZ650B1
82 Z1000J2
89 ZXR750H1
92 Blade RRN
Marmitemartian
#3 PostAuthor: Marmitemartian » Tue Feb 02, 2016 7:50 pm
Thanks for the offer that would be very helpful, just the diameter where the cones are joined and the length of the end cone would be great, many thanks.
#4 PostAuthor: warren3200gt » Tue Feb 02, 2016 7:58 pm
95mm dia x 45mm (from 95 dia to tip of exhaust)
PUM 488 June 17
76 Z900A4
77 Z650B1
77 KZ650B1
82 Z1000J2
89 ZXR750H1
92 Blade RRN
Marmitemartian
#5 PostAuthor: Marmitemartian » Tue Feb 02, 2016 8:04 pm
That's a blow, the z1000 is 114mm diameter but same length, thanks for your help.
#6 PostAuthor: warren3200gt » Tue Feb 02, 2016 8:07 pm
Plan b repair then
PUM 488 June 17
76 Z900A4
77 Z650B1
77 KZ650B1
82 Z1000J2
89 ZXR750H1
92 Blade RRN
Marmitemartian
#7 PostAuthor: Marmitemartian » Tue Feb 02, 2016 8:20 pm
So anyone got a scrap z1000 silencer I can chop the end cone off? Pretty please :D
#8 PostAuthor: warren3200gt » Tue Feb 02, 2016 8:47 pm
PUM 488 June 17
76 Z900A4
77 Z650B1
77 KZ650B1
82 Z1000J2
89 ZXR750H1
92 Blade RRN
Marmitemartian
#9 PostAuthor: Marmitemartian » Tue Feb 02, 2016 8:54 pm
They look good but the 1000 silencers have their outer manifold down pipe welded to the silencer with down pipes 2 and 3 floating, opposite way round to the 650 and the ends are Dunstall copies so if I cut the cone off to use it, it would not match my other mint oe silencer.
