I bought some of those pistons from cruzin image in Japan a while ago and I've had barrels rebored by SEP to their size.
The help I need is, I want to make sure the end gap size is within tolerance, but I can't find what the minimum should be, the workshop manual says the max is 0.7mm, but there's no minimum, can anyone advise how I work it out?
Piston Ring end gap size, 810 kit.
What we got here, is failure to comunicate.
