ST rear caliper retaining bolt
Redbeard
#1 PostAuthor: Redbeard » Sat Sep 12, 2015 7:45 pm
Hi, I have searched high and low to try and work out if the rear caliper retaining bolt on the ST that fits through the swingarm should unscrew completely. The outside bolt on mine comes off to reveal a bolt with no thread on it. Instead it seems to be a permanent fixture to the caliper which made removing the wheel a right pain in the arse because the wheel had to come out first (bevel and all) just to move the caliper! Any help appreciated. Manual says remove the bolt so I presume someone has been at it. :roll:
1979 Z1000ST
Redbeard
#2 PostAuthor: Redbeard » Sat Sep 12, 2015 7:45 pm
Outside nut I should have said.
1979 Z1000ST
#3 PostAuthor: z1bman » Sat Sep 12, 2015 7:55 pm
bolt should look identical to this & should unscrew from the the calliper
Redbeard
#4 PostAuthor: Redbeard » Sun Sep 13, 2015 11:37 am
Thanks z1bman, that's confirmed my suspicions that what I have isn't standard. That looks nothing like the bolt on mine, I will have to try and get a replacement then. Cheers for your help.
1979 Z1000ST
#5 PostAuthor: z1bman » Sun Sep 13, 2015 11:59 am
the one in the photo is for the z1300.
this is the correct part no for your z1000st
http://www.ebay.co.uk/itm/Kawasaki-NOS- ... 1200326436
Redbeard
#6 PostAuthor: Redbeard » Sun Sep 13, 2015 12:04 pm
Found one for a tenner at dk, many thanks z1bman.
1979 Z1000ST
#7 PostAuthor: z1bman » Sun Sep 13, 2015 12:07 pm
i presume it was you who purchased this one ??
http://www.ebay.co.uk/itm/Kawasaki-Z100 ... 7675.l2557
Redbeard
#8 PostAuthor: Redbeard » Sun Sep 13, 2015 4:37 pm
That's the one. Hope it fits. I managed to hacksaw two flat sides on the existing bolt and with a big adjustable spanner get the thing out of the caliper. The thread that remains looks ok and I can't see that it has been helicoiled so this replacement should work. Fingers crossed!
1979 Z1000ST
