Ignition coils
Dookbob
Ignition coils
#1 PostAuthor: Dookbob » Sat Sep 12, 2015 10:27 am
I have acquired a Z1000. 1977. From the USA, Could any member give me the procedure and resistance values to enable me to test my Ignition coils on this model. I will be grateful for any help with this.
Re: Ignition coils
#2 PostAuthor: warren3200gt » Sat Sep 12, 2015 8:23 pm
Dookbob wrote:I have acquired a Z1000. 1977. From the USA, Could any member give me the procedure and resistance values to enable me to test my Ignition coils on this model. I will be grateful for any help with this.
resistance across the input two wires should be 4+ and across the two ht leads should be 15 + to be servicable. Then do the wired george mod.
PUM 488 June 17
76 Z900A4
77 Z650B1
77 KZ650B1
82 Z1000J2
89 ZXR750H1
92 Blade RRN
Garn 1
#3 PostAuthor: Garn 1 » Sun Sep 13, 2015 8:59 am
Warren has given a basic explanation.
For more details..... test coils by setting up a normal voltmeter into "Resistance mode" with a scale 20 K ohms.
Now, measure the resistance between one end of the lead (with spark plug not connected) to the other lead of the coil to be tested.It should read approx 15k ohms. Both coils should read the same.
Next test the resistance between the low tension side of the coil. Change the scale to 10ohms. both coils should read the same ... approx 3 to 4 ohms.-
#4 PostAuthor: Pigford » Sun Sep 13, 2015 9:25 am
Hey, Dookbob..... you're not related to Babadook by any chance :??
https://www.youtube.com/watch?v=szaLnKNWC-U
:tick :tick :tick
Dookbob
ignition coils
#5 PostAuthor: Dookbob » Sun Sep 13, 2015 10:58 pm
Thanks for the info guys, I will get those coils checked out as soon as I can get back in the workshop.
Hi Pigford, no, I,m not related to Babadook.
I have found that there is one of the 6mm starter motor holding down bolts sheared about half way along its length. it,s the rear bolt of the two vertical bolts. I have been trying to come up with a plan of action to tackle this but I havn,t had any inspiration yet. has anyone had the same thing happen to them?
Problem is of course that I cant move the motor upwards because it needs to go back first , and the broken bolt that is still in place is acting like a dowel.
I,m removing the engine soon to get the frame powder coated, but the problem will still be the same .
Garn 1
#6 PostAuthor: Garn 1 » Mon Sep 14, 2015 7:49 am
Gee, that's a hard one DookBob,
Once the engine is out of the frame and after a few soaks with WD40, I would get a 6mm left hand drill and see how you go, The existing 6mm clearance hole in the alloy should act as a guide. if it doesn't budge during the drill out, make sure you leave about a quarter of an inch to grab it with pliers, once the starter is lifted.
Dookbob
ignition coils
#7 PostAuthor: Dookbob » Mon Sep 14, 2015 8:42 pm
the coils checked out ok with a reading of 5 at the primary and 15 at the HT.
I had to remove the plug caps to get a reading across the HT circuit though, the caps tested OK when I removed them so I,m thinking that the ends of the leads are hardened and worn so not making a good connection. I,m assuming that the leads cant be detached from the coils so I will see if there is enough slack in them to be able to snip them back a bit.
What is the " wired George mod" that was mentioned in an earlier post?
#8 PostAuthor: warren3200gt » Mon Sep 14, 2015 9:25 pm
There is a trick if the ht leads are too short as they are not replacable in the coil. Its not ideal but works fine. Cut the existing ht lead back until you get clean core wire. Get a thin steel self tapping screw about an inch long. Cut the head off, sharpen the cut end and screw into the cut end of the ht lead. Screw new ht lead onto the other end of the screw. Before the two ht leads butt up smear some silicon around the joint then tighten the two ht leads up. Cover with some heat shrink tube then cover that with the rubber sleeve from the old ht lead.
sounds a bit heath robinson but its the only way that I've found that doesn't let the moisture into an ht lead joint and have a big lumpy joiner visible.
wired george mod can be found here. It powers the coils direct from the battery and gives a much better spark.
http://www.wgcarbs.com/index.php/using- ... s/89-coils
PUM 488 June 17
76 Z900A4
77 Z650B1
77 KZ650B1
82 Z1000J2
89 ZXR750H1
92 Blade RRN
#9 PostAuthor: warren3200gt » Tue Sep 15, 2015 7:20 am
Or you could buy some new coils :wink:
PUM 488 June 17
76 Z900A4
77 Z650B1
77 KZ650B1
82 Z1000J2
89 ZXR750H1
92 Blade RRN
KeithZ1R
#10 PostAuthor: KeithZ1R » Tue Sep 15, 2015 7:34 am
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
