78 z1000 a1 rear brake lever spring fitting
Hi guys Im lookin advice plz , any tips on how to get the rear brake lever spring fitted ? I think I read it on here before but can't find it , many thanks
						Hi Geoff,
If you scroll down my Z1-R rebuild pics the rear brake lever and spring positioning gets mentioned a couple of times with photos.
http://www.zedrider.co.uk/z1-r.html
The pics will enlarge if you click on them - which might help you a bit.
It's much easier to work out with no swinging arm fitted !!
I made a spring puller from old wire coat hanger for this and the main stand spring.
One tip is to remove the brake lever adjusting bolt and nut from the frame - to allow it to rotate that bit extra - then re-fit them when it is on.
Good luck from Mark
Good luck from Mark
Z1-R D1, Z650 B2, Z1-B & ZRX 1200 A1P        Catch 'em if you can at www.Zedrider.co.uk
