Cylinder head removal
Gavin
#1 PostAuthor: Gavin » Sun Jul 26, 2015 3:02 pm
I have the Cams out all the head nuts + the 2 m6 bolts
But it appears to be stuck solid, I don't want to disturb the base gasket
So are there any pry points or has anyone any tips on shifting the head
Gavin
#2 PostAuthor: chrisu » Sun Jul 26, 2015 3:55 pm
always worth checking 1 more time everything is undone.
if it all is then careful use of a rubber mallet should break the seal
weaver
#3 PostAuthor: weaver » Sun Jul 26, 2015 5:14 pm
as above be very careful where you hit,the fins will break very easily,take your time and it will come loose
jonhunt
#4 PostAuthor: jonhunt » Sun Jul 26, 2015 6:19 pm
I had the same problem. In the end I gave it to a mate because I didn't wNt to force it any more. In the end the barrels came off with the head and we had to drift it off from the inside.
prowlerz1
#5 PostAuthor: prowlerz1 » Sun Jul 26, 2015 6:26 pm
If you look under the exhaust ports you will notice pry points a round raised area on barrels and a flat under the exhaust port.
73 z1 green
73 z1 brown
74 z1a brown
75 z1b red
75 z1b blue
76 z900 green
77 z1000 black
Zrx1200r
needaz1100r
#6 PostAuthor: needaz1100r » Mon Jul 27, 2015 8:25 am
You're unlikely to get it off and be completely happy you haven't disturbed the base gasket.
Mark.
johny brando
Re: Cylinder head removal
#7 PostAuthor: johny brando » Sun Aug 02, 2015 1:22 am
Gavin wrote:I have the Cams out all the head nuts + the 2 m6 bolts
Check all the head washers are removed too ...as one or two of these often remain captive & then bind up on the threads of the Head fixing studs & this will rigidly hold your Head in situ...you'll have to prize em out !
Also........ as far as not upsetting your Barrel/Base gasket joint....CAREFULLY locate the ends of a pair of Long tire levers... one on each opposing front & rear side of the Head ...these placed inbetween the & top of Barrel & the underside of the Head, there are Webbing/linking points that are there with good strong structual integrity.....look for them & identify them ..& using these points carefully you won't damage anything! Use the Tire levers in such a way that when you apply an equal downward force on Both of them ...at the same time ! they then in turn will Lift up on the underface of Head & at the same time they are then applying a downward force on the top of the Barrel & this action kill 2 birds with one stone by Lifting the Head & preserving the Base gasket joint. Break the joint one side of the motor a tiny ammount ( say about 15 thou ) .....then do the other side the same ....= Job's a goodun !
I've successfully done this on Zeds many times over the years & on many different motors too, just ensure you act carefully & find the strongest points & the longer the lever the better of course. Hope my explanation make's some sense & helps. Good luck . Johny Brando
