blowing fuses
steve bowdler
#1 PostAuthor: steve bowdler » Wed Sep 20, 2006 10:18 am
I have a problem my z1000 keeps blowing fuses at first it was every 5 miles then the other day when sitting at around 100mph it blew again this time instanly blowing on turning on the ignition.However after breakdown got me home a day later put another fuse in didnt blow help.
BShaw
#2 PostAuthor: BShaw » Wed Sep 20, 2006 10:27 am
Check main earth connections as a first step.
Baza
Jerry
President
President
#3 PostAuthor: Jerry » Wed Sep 20, 2006 4:08 pm
Then check there's nothing rubbed through or chafing at the headstock or where the looms go into the headlamp.
bunnysZ
Granny Magnet
#4 PostAuthor: bunnysZ » Wed Sep 20, 2006 6:35 pm
I had this prob not long ago with the main fuse only , it was an exposed wire from the fuse that kept blowing the fuse.
is yours all fuses or just one fuse ?
steve bowdler
#5 PostAuthor: steve bowdler » Wed Sep 20, 2006 8:01 pm
It is just blowing the main fuse or should I say was, after I left it for a day it stopped blowing either something moved or cooled down.I have bought a new regulator/rectifier and checked cables near headstock.
Jon
#6 PostAuthor: Jon » Thu Sep 21, 2006 7:46 am
Yeah to be honest best bet is to take off the bodywork and just be methodical and check over whole loom covering for splits, and give every connector a good clean up. Should find the problem and its peace of mind for the future too. :)
ash
#7 PostAuthor: ash » Thu Sep 21, 2006 8:27 am
Plus convert to blade fuses as the old round type are crap,
Iain marshall
#8 PostAuthor: Iain marshall » Thu Sep 21, 2006 9:05 am
Steve have a good look at the wiring as it goes into the headlight shell,i've had a few problems there in the past
#9 PostAuthor: Rich » Thu Sep 21, 2006 3:54 pm
Take the bodywork and tank off, replace fuse with 1/4" nail turn ignition on and see where the smoke / heat comes from first! It could be high resistance on the wire that's doing it, even if the connectors look Ok if it's the original loom all the wires will probably be oxidising under the plastic. Otherwise as stated check headstock wiring especially the white ignition switch feed.
Iain marshall
#10 PostAuthor: Iain marshall » Thu Sep 21, 2006 5:32 pm
Rich I/you only do that with H****as,but it works better with a 5/16(8mm for the younger ones)bolt :)
#11 PostAuthor: Pigford » Thu Sep 21, 2006 7:12 pm
Is that galv or copper nails..... Do coach bolts work ok ?
#12 PostAuthor: Rich » Thu Sep 21, 2006 7:17 pm
You only need a 1/4 with a kawa they don't have such a good charging system as H**** s, 8mm is a bit over the top, you may even be able to go down to 6mm without blowing it!!!
I did that on a trident T150V of mine, worked a treat, it was a knackered zener doing it, unplugged zener, rode her home and replaced zener and bit of wire - no problems after that.:cool:
