Tacho drive seals
phil1r
Tacho drive seals
#1 PostAuthor: phil1r » Fri Jun 05, 2015 9:30 pm
Hi Guy's, can you change the inner seal in this unit :?: outer O ring no problem but pissing oil from the centre seal. Is this available as a kit or whole assembly, anyone got info on this and where from. :??
#2 PostAuthor: z1bman » Fri Jun 05, 2015 9:51 pm
genuine seal still available cradley have it in stock £5.40
pertonpc
#3 PostAuthor: pertonpc » Fri Jun 05, 2015 9:59 pm
Hi Phil,
Take a look on these pics. You can see the inner and outer seal and the part number you need.
Think it is picture 16 as you scroll down
From Mark
http://www.zedrider.co.uk/z1-b.html
phil1r
#4 PostAuthor: phil1r » Fri Jun 05, 2015 10:09 pm
z1bman wrote:genuine seal still available cradley have it in stock £5.40
Nice :) I'll be over to get one. Many thanks
phil1r
#5 PostAuthor: phil1r » Fri Jun 05, 2015 10:11 pm
pertonpc wrote:Hi Phil,
From Mark
This should be the same for a Z1R I would think :?:
#6 PostAuthor: z1bman » Fri Jun 05, 2015 10:14 pm
you need to inspect the tacho gear shaft & make sure it is not worn where the seal grips the shaft. also fit a z650 fibre washer between the cable & the threaded part of the tacho drive
