Triumph Speed Triple Fuel Pump
nigel bessant
#1 PostAuthor: nigel bessant » Thu May 21, 2015 9:31 pm
This is an ongoing problem with my speed triple.
My old pump assembly has a flow and return to the throttle bodies but the replacement as pictured below only has one outlet.
Am I right in assuming that the pumped flow on the one below has an integral tee or similar that incorporates the pressure regulator rather than having a fuel return?
Would the pump assembly below work on my speed triple? It's off a 1050 sprint
Apologies if this is badly explained.
Any help appreciated and before anyone says "ask a triumph forum"............did that!
CAT3
#2 PostAuthor: CAT3 » Sat May 23, 2015 10:39 pm
Which Triumph forum have you asked, is it www.triumphtorque.com ?
If not, I'd try this forum, there's some very knowledgeable members on there.
I can't help, my Triumph sounds like the same set-up as yours !
nigel bessant
#3 PostAuthor: nigel bessant » Sun May 24, 2015 9:05 pm
CAT3 wrote:Which Triumph forum have you asked, is it www.triumphtorque.com ?
It's not the one you mentioned but I'll give that one a try.
Nigel
